lift pump
lift pump
Postby bigtrev » Wed Aug 05, 2015 10:08 pm
Looking for cummins part numbers for low pressure pump upgrade parts I know hungry diesel has a kit but with the Canadian exchange rate it's not plausible I've found many numbers but non seem to be the rite ones help !!!
bigtrev
Re: lift pump
Postby lz69 » Thu Aug 06, 2015 1:09 pm
Not sure how much you would save, this post is a few years old but at the time the Canadian list price was double the US list price. It has all the part numbers for the pump, fuel line, spacer and so on.
Last thing to add is that the pump Eric sells is actually different then the one you can buy from cummins, it's a 94-98 high volume pump that has a different spring installed. These pumps it has a larger piston that can supply more fuel. He also sells the spring separate so buying one and getting a 94-98 pump from cummins in Canada may be cheaper
http://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/dang-piston-lift-pump-84412/
lz69
Re: lift pump
Postby bigtrev » Fri Aug 07, 2015 5:39 pm
I didn't know hungry diesel sold the spring separate I will defiantly look into that I was trying to find the spring also I am aware that the piston is bigger in the 94+ but by looking at it just didn't look that much bigger but who knows with out actual numbers thnx trev
bigtrev
Re: lift pump
Postby oldestof11 » Fri Aug 07, 2015 5:43 pm
Bigtrev, contact Eric on here. Goes by RCCUMMINS. The spring isn't listed on his site.
Re: lift pump
Postby RCCUMMINS89 » Fri Aug 07, 2015 7:18 pm
Users browsing this forum: No registered users and 72 guests
