What is the plastic cover on the drivers side of the engine.
Postby Turbo67 » Thu Aug 13, 2015 10:53 pm
So, I removed my VE pump to seal it up a few weeks back. What is that cheap looking plastic "cover" attached to the side of the engine block behind the pump?
Turbo67
93 Cummins 5.9L, VE Pump, 300,000 miles
4200 RPM Spring, indexed stock fuel pin, Fuel Screw maxed, then replaced with longer "Hot Screw", aneroid screw tweaked
Turbo67
Re: What is the plastic cover on the drivers side of the engine.
Postby thrashingcows » Fri Aug 14, 2015 2:24 am
That is insulation to help muffle the solid lifter noise just behind it.
thrashingcows
Postby Turbo67 » Fri Aug 14, 2015 7:55 am
Thanks for the quick reply. I wanted to remove it to inspect it, see what it was, but that would of been diving head first into a tight area!
I appreciate the information.
Turbo67
Turbo67
Users browsing this forum: No registered users and 72 guests
