fan clutch
fan clutch
Postby odee » Tue Sep 01, 2015 2:43 pm
does anybody know the difference between the cooling fan clutch on the intercooled engine vs the non. thanks
odee
Re: fan clutch
Postby thrashingcows » Fri Sep 04, 2015 10:09 am
I don't think there is any difference. The clutch is "basically" the same from 89-02-ish. When my OEM 89 unit seized up I replaced it with a 2nd Gen unit....worked fine.
thrashingcows
Re: fan clutch
Postby CumminsPower59 » Fri Sep 04, 2015 10:19 am
It's the hub (part that mounts to the block) that is different between IC and NON-IC engines.
Users browsing this forum: No registered users and 72 guests
