Non w/g hx35 on 93
Non w/g hx35 on 93
Postby countrymoparguy » Fri Sep 04, 2015 5:35 pm
I'm looking at a non-wastegated hx35 off a 95 12V. Am I going to need to run a wastegate on it or am I fine to run it as it is? Truck it's going on is a 93 d250 with the g360. Thanks for the help.
countrymoparguy
Re: Non w/g hx35 on 93
Postby dazedandconfused » Sat Sep 05, 2015 8:19 am
If its a stock Hx35 it will have a gated 12cm exhaust housing.
Postby thrashingcows » Sat Sep 05, 2015 3:07 pm
Even if it's not I would not be too concerned about it...unless you don't have gauges. If your IP is mostly stock with nothing more then the fuel pin turned 90*, then I don't think you'll see more the 20-25lbs boost or so.
I recently added a 14cm housing to my motor, and my IP is stock except the rotated stock fuel pin. I'm lucky to see 18-19lbs boost. But then I'm also running a big Power stroke IC, so that will eat up a couple lbs of boost. ;)
thrashingcows
