2nd port on oil filter housing ?
Postby jethro » Thu Sep 10, 2015 12:34 am
on top of the oil filter housing is the port feeding oil to the turbo. What is the other port for ????
I have an oil pressure gauge in it from when it was on the engine stand- what is supposed to go in that hole ?????
Can I use it for an oil pressure sensor ?
Tim
jethro
Re: 2nd port on oil filter housing ?
Postby delsilver » Thu Sep 10, 2015 3:40 am
It can be used for whatever you need, I am using it for the feed for my bypass filter.
Del
Delsilver
93 W250
Fuel pin turned 90 deg, starwheel turned down, timing 1/8 adjust
delsilver
Postby PToombs » Thu Sep 10, 2015 4:34 pm
It's just an extra port. I have seen gauge senders in there on industrial engines. I use it to feed my 2nd turbo.
Postby jethro » Fri Sep 11, 2015 8:43 pm
OK- cool !
jethro
Users browsing this forum: No registered users and 57 guests
