pinion kits
pinion kits
Postby jethro » Mon Sep 14, 2015 11:16 pm
Reccomendations for who sells a kit for replacing the pinion bearings and races for a daina 60 rear ?
jethro
Re: pinion kits
Postby Gots_a_sol » Tue Sep 15, 2015 4:18 am
Randy's Ring and Pinion.
Is this in your Super duty?
-Joe
Gots_a_sol
Re: pinion kits
Postby jethro » Tue Sep 15, 2015 3:48 pm
yes in the f-350 I built up. Its so loose I can wiggle the input shaft about 1/4 inch lateraly !
It had about a 6 inch lift from previous owner. I will at some point try to reduce the lift by at least half.
I suspect that might be why the bearings are shot.......
Tim
Thanks I will look them up !
jethro
Re: pinion kits
Postby Gots_a_sol » Tue Sep 15, 2015 4:16 pm
Super duty has a sterling 10.5 rear not a dana axle (assuming single rear wheels).
-Joe
Gots_a_sol
Re: pinion kits
Postby jethro » Tue Sep 15, 2015 6:28 pm
OK ! That's good to know-
just found the data tags last nite. they had been painter over with black paint.
Single rear wheel f-350, 2004
Numbers on pumpkin are:
V 423 F L73 105 3H08
jethro
Users browsing this forum: No registered users and 72 guests
