Stage 1 or 2 Denny t
Postby 92cummins89 » Tue Sep 22, 2015 8:45 pm
Lookin at getting a fuel pin an can't seem to find a difference in the stage one an two Denny t fuel pins
92cummins89
Re: Stage 1 or 2 Denny t
Postby CumminsPower59 » Wed Sep 23, 2015 5:19 am
May I recommend THD's fuel pin? Lots of great reviews and comparisons vs. DennyT products ;)
Postby oldestof11 » Wed Sep 23, 2015 8:08 am
Denny T 1 if you're set on Denny.
I have never read a bad review on any pin except BullyDog's.
Postby 92cummins89 » Wed Sep 23, 2015 5:02 pm
The hungry diesel right ?
I completely forgot bout them
92cummins89
Postby wheelerfreak » Sun Oct 11, 2015 2:46 pm
I had a Denny T stage one and for the most part loved it...It did allow the pin to travel too far and leaked fuel though.
wheelerfreak
Postby 1320Fastback » Thu Dec 31, 2015 6:00 pm
^Same here. I bought my current truck with a Denny pin in it and it leaks fuel also.
The previous owner installed it the week prior and the leak was the last straw.
I have a BD pin on the way and will change it when I get it and see if the leak stops.
Also have a VE reseal kit on order.
92 D250, Getrag 5 Speed, 3.54, extra cab, long bed, AC works, Airbags.
1320Fastback
Postby spencerdiesel » Fri Jan 01, 2016 1:15 pm
I vote the THD pin as well. Flat ramp profile, and cut deep enough to allow full fuel but will not cause o ring failures.
Bottom end fueling is very mild which I LIKE for anyone planning on big fuel later down the road. Low end fuel becomes hard (impossible?) to tune out with big injectors and a hard low end fueling pin.
H1C/18
Muffler delete
spencerdiesel
Postby spencerdiesel » Fri Jan 01, 2016 1:17 pm
Even if you never plan on much fuel, you can still always tune the AFC (with THD or BD pin) to fuel as you like.
H1C/18
Muffler delete
spencerdiesel
Postby cougar » Sun Jan 03, 2016 10:12 am
wheelerfreak wrote:I had a Denny T stage one and for the most part loved it...It did allow the pin to travel too far and leaked fuel though.
This can happen with any aftermarket fuel pin. It is because the pin (the follower) that follows the fuel pin is not use too the extra travel. Both my 91 and 92 leaked until the follower wore into it's new travel, then it stopped.
01 2500 "the work truck".
cougar
Postby Remps » Sun Jan 03, 2016 12:04 pm
When installing an aftermarket pin, or grinding the stocker, one should remove the throttle linkage and the plug on the afc behind the follower pin and lube and work the crap out of it. Seems to be a common issue when modifying a 25 year old pump. Less chance of leaking or sticking if one does this.
