Cycling grid heater more than once
Postby spencerdiesel » Wed Nov 04, 2015 4:53 pm
I've heard cycling the grid heater more than once or twice isn't recommended, anyone wanna shed light for me?
H1C/18
Muffler delete
spencerdiesel
Re: Cycling grid heater more than once
Postby PToombs » Wed Nov 04, 2015 5:29 pm
If it's real cold out a couple times helps a lot. If it's only 15 or 20 out once is usually enough.
Postby BC847 » Wed Nov 04, 2015 6:15 pm
And before it starts worrying you, you don't need to upgrade the stock/OEM battery system, provided your existing battery is in good shape. ;)
Postby spencerdiesel » Wed Nov 04, 2015 7:14 pm
Thanks guys
H1C/18
Muffler delete
spencerdiesel
Postby rhinodart » Mon Nov 09, 2015 1:40 pm
I have heard this also, but nobody has ever come up with a reason it is bad, so I will keep doing it in the great white nort.
rhinodart
Postby spencerdiesel » Mon Nov 09, 2015 6:24 pm
Yea I've only seen it in one of the "caution" blocks in a manual somewhere, saying that grids shouldn't be cycled back to back for some funky reason.
H1C/18
Muffler delete
spencerdiesel
Postby 1320Fastback » Fri Jan 01, 2016 8:49 am
They must be worried or have tested them to failure.
The more rapid cycles they thru go thru the hotter and hotter the grid becomes. Eventually when it fails it may crack and pieces could be sucked into the motor.
Similar to a incandescent light bulb filament when it breaks. In a way it is a grid heater when on.
92 D250, Getrag 5 Speed, 3.54, extra cab, long bed, AC works, Airbags.
1320Fastback
Postby spencerdiesel » Fri Jan 01, 2016 10:41 am
Now that'd make some sense too
H1C/18
Muffler delete
spencerdiesel
Postby PToombs » Fri Jan 01, 2016 4:48 pm
I have seen grid heater failures on machines. One was so bad the heater coils were gone from the unit. One of the other techs was working on that one and I don't remember what or if it did inside the engine.
Postby spencerdiesel » Fri Jan 01, 2016 8:41 pm
Thats the good stuff that gives me bad dreams :cry:
H1C/18
Muffler delete
spencerdiesel
Postby ofelas » Sat Apr 09, 2016 12:20 pm
This past winter my grids din't even cycle, but I had zero problems cranking the old girl up at -40......
R12 = liquid bilit
ofelas
Postby spencerdiesel » Sun Apr 10, 2016 3:09 pm
What'd it take to start it?
H1C/18
Muffler delete
spencerdiesel
Postby ofelas » Sun Apr 10, 2016 3:32 pm
Ah I'm cheating aren't I.
A Webasto.
R12 = liquid bilit
ofelas
