Altitude vs air temp affect on power
Postby spencerdiesel » Fri Nov 06, 2015 4:19 pm
I like numbers, maybe too much. Anyone have specs/experience with how much air temp must decrease for X amount of increased altitude to maintain the same power/EGTs? For example, if 80 degrees F @ sea level supports X amount of power, what temp would it have to be @ 5,000 ft to support the same power? Assuming it is a linear function etc....
H1C/18
Muffler delete
spencerdiesel
Re: Altitude vs air temp affect on power
Postby Remps » Fri Nov 06, 2015 5:42 pm
Check out Garretts Boost adviser, available as an app. You can punch in all different numbers, boost, altitude, pressure drop, intake temp, etc. Pretty cool.
Postby spencerdiesel » Fri Nov 06, 2015 6:05 pm
Great idea :D
H1C/18
Muffler delete
spencerdiesel
Postby cougar » Sat Nov 07, 2015 11:57 am
Density altitude. Go to a pilots shop and pick up a cheap E6B calculator. Should come with instructions, but someone should be able to teach you how to use it.
01 2500 "the work truck".
cougar
Postby spencerdiesel » Sat Nov 07, 2015 4:03 pm
Another toy ;)
H1C/18
Muffler delete
spencerdiesel
Postby Remps » Sun Nov 08, 2015 10:05 pm
I had a chance to play with a density altitude meter a couple years ago, at 1000 ft above sea level, minus 30 celsius outside, density was equal to 1000 ft below sea level. :grin:
Postby spencerdiesel » Mon Nov 09, 2015 6:13 pm
So if florida freezes over there will be 500 hp VE's everywhere? :lol:
H1C/18
Muffler delete
spencerdiesel
Postby RCCUMMINS89 » Mon Nov 09, 2015 7:04 pm
But wait now...... don't tell that to all of the non believers in correction factors. (I'm not saying that correction factors are always correct).
But I will say it is pretty hard to make a big non corrected number at elevation, in the summer.
Postby spencerdiesel » Mon Nov 09, 2015 7:14 pm
True dat
H1C/18
Muffler delete
spencerdiesel
