Valet brainstorming
Valet brainstorming
Postby spencerdiesel » Fri Nov 06, 2015 4:28 pm
I've read a thread or two about different approaches to valet installations etc, but with the gov cracking down more (a lot of smoked out redlights/pedestrians where I am :( ), I'm curious to hear any and all approaches to fuel-limiting-from-the-cab ideas. All thoughts welcome.
H1C/18
Muffler delete
spencerdiesel
Re: Valet brainstorming
Postby AHineman » Fri Nov 06, 2015 5:25 pm
Valet switch doesn't limit low boost fueling/smoke just doesn't let boost increase the fueling....but here is mine.
Switch to control this and pressure switch for ksb is in the dash with leds to indicate what's up.
1st gen ksb/vallet switch: https://youtu.be/JscJypDes1Y
Postby spencerdiesel » Fri Nov 06, 2015 5:33 pm
Real good looking setup. Limiting full fuel is more important to me, so that's good to know. How much EGT/power/boost drop do you get with your setup?
H1C/18
Muffler delete
spencerdiesel
Postby AHineman » Fri Nov 06, 2015 5:36 pm
Been awhile since I drove it, but I think it knocks about 20 psi off the boost (from 70 to 50). Egts were never an issue so I don't remember.
Postby spencerdiesel » Fri Nov 06, 2015 5:41 pm
Dang, you've got a pee pump eater 8) Wow that would be nice.....
H1C/18
Muffler delete
spencerdiesel
Postby PToombs » Fri Nov 06, 2015 6:22 pm
I have the same setup, but mine is mounted direct to the AFC cover.
Postby spencerdiesel » Fri Nov 06, 2015 8:59 pm
I'll have to follow suit eventually!
H1C/18
Muffler delete
spencerdiesel
