Bookshelf wrote:At what power level do piston lift pumps become inadequate? I'm talking about either the first gen style or the second gen ones you need to use a regulator with. Also, used in conjunction w/ a piston pump, when are the stock size lines a liability? I'm going to upgrade the turbo/injectors on one of my trucks this coming year, but don't want to get too greedy and have to end up doing a fuel system. Thanks-Nick
GLHS wrote:The smallest tubing is the white plastic pickup inside the tank.
I think it's 7/32"?
cummins king wrote:wow thats small, i wonder if it will suck a half inch lines witch my new pick up will be
ford69557ci wrote:you are correct the larger lines screw with part throttle driveablitly but does make for a killer soundin idle
