Who likes what lube
Re: Who likes what lube
Postby spencerdiesel » Mon Feb 15, 2016 7:01 am
I take the tower off and fill it from the top. Only reason is because snap rings don't bother me too much.
H1C/18
Muffler delete
spencerdiesel
Postby spencerdiesel » Mon Feb 15, 2016 7:08 am
Oh but you will want someone to hold the tower/spring compressed while you re install the snap ring
H1C/18
Muffler delete
spencerdiesel
Postby DMan1198 » Mon Feb 15, 2016 7:41 am
After the amount of times I threw the channels locks putting the comp housing on my secondary I'll pass this time
Postby spencerdiesel » Mon Feb 15, 2016 7:50 am
Could always park sideways on a steepie and get it in that way :D
H1C/18
Muffler delete
spencerdiesel
Postby DMan1198 » Mon Feb 15, 2016 8:17 am
I have the benefit of access to a lift, so I generally use that, but I could probably just lift one side
Postby spencerdiesel » Mon Feb 15, 2016 3:22 pm
What lube you gonna use
H1C/18
Muffler delete
spencerdiesel
Postby PToombs » Mon Feb 15, 2016 5:23 pm
I put a 90* street ell on mine, it brings up just perfect for the extra quart.
When I have to pull the shifter I shanghai one of my kids and he holds the 2x4 under the heater box and pushes the stub down. ;)
Postby Richie O » Tue Feb 16, 2016 10:45 am
I take out a pto cover bolt and use a squirt cap from a quart gear oil jug.
Postby spencerdiesel » Tue Feb 16, 2016 1:03 pm
This getrag has always talked to me but now it's becoming more vocal.....really not in a desireable transmission-rebuilding stage right now :|
H1C/18
Muffler delete
spencerdiesel
Postby CumminsPower59 » Thu Feb 18, 2016 2:58 pm
spencerdiesel wrote:Oh but you will want someone to hold the tower/spring compressed while you re install the snap ring
Use your chest to push on the shifter enough to get the spring compressed and it frees up your hands for the snap ring installation.
Postby spencerdiesel » Fri Feb 19, 2016 6:59 am
Never thought about it, I'll have to try it
H1C/18
Muffler delete
spencerdiesel
Postby Kobane » Sun Apr 03, 2016 9:59 pm
Amsoil HDD 5w-30 Diesel oil has a lot of Zinc and anti-wear additives. I use it in my Ford 6.0, used oil analysis and the whole 9 yards. It is an excellent motor oil. Our reliability group has placed it in the top 2 for their next supplier for our mining machinery.
Kobane
Postby spencerdiesel » Tue Apr 05, 2016 8:50 am
How much is it for 3 gal.?
H1C/18
Muffler delete
spencerdiesel
Postby ofelas » Sat Apr 09, 2016 11:59 am
Agreed. I get it at great prices from my very compliant dealer.
Also use their ATF & Severe Gear 75W90.
Kobane wrote:Amsoil HDD 5w-30 Diesel oil has a lot of Zinc and anti-wear additives. I use it in my Ford 6.0, used oil analysis and the whole 9 yards. It is an excellent motor oil. Our reliability group has placed it in the top 2 for their next supplier for our mining machinery.
R12 = liquid bilit
ofelas
Postby spencerdiesel » Sun Nov 13, 2016 10:10 am
Picked up some delo from walmart the other day and noticed the regular rotella t3 had been replaced with a new t4. I think its ck rated or something, anyone know if chevron or anyone else will follow suit soon?
H1C/18
Muffler delete
spencerdiesel
