89 D250 muffler delete
Postby ggreenall90 » Sat Jan 02, 2016 12:51 pm
If i remove the stock muffler on my 89, will i need a bent piece of replacement pipe or just a straight piece cut to the needed length? TIA
ggreenall90
Re: 89 D250 muffler delete
Postby thrashingcows » Sat Jan 02, 2016 1:35 pm
Should be a straight center inlet/outlet muffler....but I would visually check it to confirm that it is. If it is then a straight piece of pipe will get you going. If not then look for a piece of flexible 3" exhaust pipe....very easy to make a short "S" curve with it. ;)
thrashingcows
