Lift pump/Fuel filter Q
Postby 79Powerwagon » Tue Feb 09, 2016 4:09 pm
I am looking to stick a Cat 1R-0750 fuel filter and some sort of a water seperator on my 79 power wagon with the 93 6BT, bypassing the stock setup. I'm wondering what GPH rating i should be looking for in a water seperator. I will be running a HVLP piston pump setup for the rotary IP.
Thanks
79Powerwagon
Re: Lift pump/Fuel filter Q
Postby RCCUMMINS89 » Tue Feb 09, 2016 7:13 pm
60gph or so will be enough.
Postby 79Powerwagon » Wed Feb 10, 2016 1:12 pm
RCCUMMINS89 wrote:60gph or so will be enough.
Thank you.
79Powerwagon
Postby 79Powerwagon » Wed Feb 24, 2016 2:15 pm
Is it recommended to install a filtration setup between lp and ip, or will the piston pump pull fuel through filters ok?
79Powerwagon
Postby PToombs » Wed Feb 24, 2016 3:23 pm
You should put at least a strainer before a piston LP, then the main filter should be between the LP and IP.
Postby 79Powerwagon » Wed Feb 24, 2016 5:11 pm
Would a water seperator be acceptable between Lp and tank?
79Powerwagon
Postby spencerdiesel » Wed Feb 24, 2016 7:53 pm
Depends on the extent it filters to. I'd guess a 75 - 150 micron inline filter (like on a gasser) would be fine to protect the LP and not have to be replaced every Saturday . But that would be a strainer, instead of a FF/FS.
H1C/18
Muffler delete
spencerdiesel
Postby spencerdiesel » Wed Feb 24, 2016 7:54 pm
Short answer yes.
H1C/18
Muffler delete
spencerdiesel
Postby PToombs » Thu Feb 25, 2016 5:32 pm
I'm running a 10 micron Racor water separator between the tank and the LP, why not? I also have 1/2 lines to the LP from a sump, so it draws easier than from a stock pickup.
Postby 79Powerwagon » Thu Feb 25, 2016 5:40 pm
PToombs wrote:I'm running a 10 micron Racor water separator between the tank and the LP, why not? I also have 1/2 lines to the LP from a sump, so it draws easier than from a stock pickup.
That's about what I'm thinking on doing. But I have 3/8 lines. Guess I'll see how it goes.
79Powerwagon
Postby spencerdiesel » Thu Feb 25, 2016 6:54 pm
Hey, if all that clouds your brain is internal combustion and waste oil (like yours truly) I'd have stainless strainers starting at 1000 in the filler neck and working down to 1 mic absolute at the cyl head 8)
H1C/18
Muffler delete
spencerdiesel
