Anyone have experience with an ICEBOX Air filter system???
Postby Cole92w250 » Tue Mar 08, 2016 9:05 pm
ICEBOX Ams filter?
Cole92w250
Re: Anyone have experience with an ICEBOX Air filter system???
Postby thrashingcows » Tue Mar 08, 2016 9:41 pm
thrashingcows
Postby thrashingcows » Tue Mar 08, 2016 9:44 pm
Nice set-up...but I don't buy into the "Cotton" high air flow filters....if they are so great then why doesn't the commercial trucking industry use them. ;) And I'm a commercial trucker BTW. :mrgreen:
I've also had very bad performance from these filters...letting all kinds of debris through that a paper filter element would never let through. Only paper for me...on all my vehicles..ever!
thrashingcows
Postby Cole92w250 » Tue Mar 08, 2016 10:01 pm
Good point. Still looking... any suggestion
Cole92w250
Postby liftarc » Wed Mar 09, 2016 1:19 pm
How much actual value is there to a cai system on an intercooled turbo engine? Seems to me an oversized paper filter should be plenty on that end and efforts towards cooling charge air would be better spent on the intercooler itself.
92 D350 club cab flatbed dually-201k G360, NP205,D60 swap soon
92 Ramcharger 5.9 Magnum, 46rh, NP241-238k
liftarc
Postby PToombs » Wed Mar 09, 2016 5:22 pm
A BHAF will support a lot of horsepower, never had any problems with a paper filter.
Postby BC847 » Wed Mar 09, 2016 9:58 pm
The problem with that system is the fact it's NOT a cold-air intake. A fancy rain-shield yes, cold air, no
Postby thrashingcows » Wed Mar 09, 2016 11:52 pm
PToombs wrote:A BHAF will support a lot of horsepower, never had any problems with a paper filter.
That is what I would do first...BHAF...is I needed more air flow on a paper filter. :mrgreen:
thrashingcows
Postby PToombs » Thu Mar 10, 2016 4:39 pm
BC847 wrote:The problem with that system is the fact it's NOT a cold-air intake. A fancy rain-shield yes, cold air, no
True!
Postby BC847 » Sat Mar 12, 2016 9:18 pm
liftarc wrote:How much actual value is there to a cai system on an intercooled turbo engine? Seems to me an oversized paper filter should be plenty on that end and efforts towards cooling charge air would be better spent on the intercooler itself.
- Our engine uses air as the working medium. At a given altitude, coupled with a given temperature, we have a medium of a given density. Changing any of the former, directly alters the latter.
It's more efficient and cost effective to begin with a denser medium (cooler air). The addition of a charge-air cooler (CAC AKA: AC or IC) regains some of the increase in density lost by the addition of the heat of compression introduced by way of the turbo.
In the gasser world IIRC, every 10*F decrease in charge-air temperature results in a 1% power increase across the entire RPM range.
Postby liftarc » Wed Mar 23, 2016 12:21 pm
BC847 wrote:It's more efficient and cost effective to begin with a denser medium (cooler air).
Good point. I'd be interested in seeing the actual effect on post-turbo and then post-cac density of changing intake air temps but I'm not about to do all that calculating...
liftarc
