Fans
Fans
Postby 79Powerwagon » Thu Mar 31, 2016 4:59 am
Anyone try a flexalite mechanical fan? Supposed to be lighter and less drag at high rpm. Gimmick? For around 50 bucks it may be worth a try....
79Powerwagon
Re: Fans
Postby thrashingcows » Thu Mar 31, 2016 10:10 pm
The problem is attaching it to the threaded end on the fan hub...;)
thrashingcows
Re: Fans
Postby 79Powerwagon » Fri Apr 01, 2016 6:09 am
Or attach it to the clutch hub.
79Powerwagon
Re: Fans
Postby thrashingcows » Fri Apr 01, 2016 9:31 am
79Powerwagon wrote:Or attach it to the clutch hub.
Tried that with a big 7 bladed gasser unit once....the fan does not have the "Big dish" required to clear the clutch and put the blades far enough away from the motor to not hit anything. ;)
thrashingcows
Re: Fans
Postby 79Powerwagon » Fri Apr 01, 2016 9:39 am
Well, good thing I asked. Thanks.
I don't mind doing some fab but sounds like it may not be worth the effort.
79Powerwagon
