oil temp sensor possible position
Postby jethro » Fri Apr 01, 2016 7:33 pm
My ford has oil temp in dash but I understand cummins didn't have a place on engine for a sensor.
(could have welded a fitting into pan if I had thought that far ahead..... :lol: )
The only general area I can think of to measure oil temp would be the lines for turbo. First thought of return (drain)
line - but wondered if oil might be hotter or cooler there than in engine.
Then I wondered (!) if I could make a fitting that would bo in between the oil supply line and the hole where it screw into
the filter adapter. That intermediate fitting could have a port for the screw-in temp sensor......
Would that work OK ?????
Any failure modes ?
Tim
jethro
Re: oil temp sensor possible position
Postby PToombs » Sat Apr 02, 2016 11:53 am
Can't you adapt it into the 2nd port on the filter head? If not, Teeing into the turbo line may work.
Postby jethro » Sat Apr 02, 2016 10:33 pm
Yes- I think that is what I am referring to---- the filter housing has 2 ports on the top-- one bigger and one smaller-
I have an oil pressure switch (ford's idiot-switch) in the little one ( 1/8 npt) and the bigger one - has the turbo supply line in it.
I thought the bigger threaded hole would be easier to add an intermediate fitting into........
Does that sound reasonable ?
jethro
Postby lz69 » Sun Apr 03, 2016 1:27 pm
One teed into the vacuum pump supply line may work as well
lz69
Postby PToombs » Sun Apr 03, 2016 3:56 pm
You could Tee into any of the 3 fittings and be ok. Might be kinda tight using the one feeding the vacuum pump though.
Postby Kobane » Sun Apr 03, 2016 9:52 pm
Most diesels run their temp sensor post oil cooler. Not sure if the 6bt filters oil before or after, but it could be a safe bet to plumb it in around the filter housing. I wouldn't use the turbo oil line, usually turbo oil is post rotating assy and the drain is right to pan (at least with most L10, M11, N14 engines)
Kobane
Postby PToombs » Mon Apr 04, 2016 4:20 pm
Kobane, the turbo oil line comes direct off the filter head. I'm not sure if the cooler is before or after the filter either, never thought about it before.
