Engine wont shut off.
Postby Cole92w250 » Wed Apr 06, 2016 4:32 pm
Just happened today, My engine wouldnt shut off after the key was turned back. Hot weather bad fuel play into effect. Any tips?
Cole92w250
Re: Engine wont shut off.
Postby Philip » Wed Apr 06, 2016 4:52 pm
Most likely took the tip off the fuel solenoid plunger. Replace the plunger and back the fuel screw out.
Swap to a pull cable if you don't want to turn down the fuel.
Postby spencerdiesel » Wed Apr 06, 2016 7:10 pm
Let off the throttle more slowly. Side stepping at WOT/full boost will demolish the plunger.
H1C/18
Muffler delete
spencerdiesel
Postby fatty » Wed Apr 06, 2016 8:02 pm
Not really Spencer. If you turn up the pump its only a matter of time until the FSS fails.
Postby Cole92w250 » Wed Apr 06, 2016 10:19 pm
haha you guess right Spencer. See how it goes...
fuel shut off pull cord seems clever. And im guessing ill need bigger injectors soon if I want to keep my pump tweaked.
Cole92w250
Postby spencerdiesel » Thu Apr 07, 2016 6:45 am
I was under the impression the most stress on the plunger was when the throttle was chopped flowing a lot a fuel with small injectors, and the sudden backwash could eat it?
So how does it happen? That's just all I've heard, so I assumed that's how it was
H1C/18
Muffler delete
spencerdiesel
Postby PToombs » Thu Apr 07, 2016 4:32 pm
That's what I was told too. It could be more fuel flowing erodes the tip also, but bigger injectors alleviate the problem usually.
Postby spencerdiesel » Thu Apr 07, 2016 5:36 pm
Guess ill just have to max the pump and see
H1C/18
Muffler delete
spencerdiesel
Postby fatty » Thu Apr 07, 2016 7:24 pm
I guess I should have specified with stock injectors it's going to break.
Postby Cole92w250 » Fri Apr 08, 2016 3:23 pm
bit of the tip that came off. So I did the 600gr and sanded a VERY LITTLE BIT off. Installed back in and its back to normal. Still pump tweak at 31psi.
Cole92w250
Postby spencerdiesel » Fri Apr 08, 2016 7:54 pm
Well dang we all know that :grin:
H1C/18
Muffler delete
spencerdiesel
Postby fatty » Fri Apr 08, 2016 11:13 pm
You just joined here six months ago and you know everything?
Postby PToombs » Sat Apr 09, 2016 12:23 pm
Seems like it sometimes. Maybe he's a prolific reader? ;)
Postby Cole92w250 » Sat Apr 09, 2016 9:43 pm
common men were 1st gen owners not hemi boys
Cole92w250
Postby spencerdiesel » Sun Apr 10, 2016 3:16 pm
I didn't join with zip for knowledge. I've learned a lot of things here, but most of the things I know were prior.
Sorry to come off that way
H1C/18
Muffler delete
spencerdiesel
