Advance timing
Advance timing
Postby Cole92w250 » Thu Apr 14, 2016 7:27 am
when is it a good time to AT on the injection pump?
92 intercooled, 3200, fuel pin, 16cm/60mm, turbo bak 3.5
31psi
Cole92w250
Re: Advance timing
Postby PToombs » Thu Apr 14, 2016 4:36 pm
Any time! Since you have a spring and fuel pin it won't hurt to do it now. A 1/8 inch bump will lower EGTs and give a little more hp. It will lower boost, so don't be alarmed when it goes down some.
Re: Advance timing
Postby fatty » Thu Apr 14, 2016 6:08 pm
Start with 1/8 inch like Pete said.
Re: Advance timing
Postby Cole92w250 » Thu Apr 14, 2016 8:13 pm
Will this help lower my idle speed? Im sitting @900 rpm .Thanks guys
Cole92w250
Re: Advance timing
Postby fatty » Thu Apr 14, 2016 10:48 pm
Won't change the idle. 900 in neutral?
Re: Advance timing
Postby Cole92w250 » Fri Apr 15, 2016 9:06 pm
yeah about that Fatty. Just finished the ATimming what if i went acouple hairs past 1/8?
Cole92w250
Re: Advance timing
Postby fatty » Fri Apr 15, 2016 9:22 pm
Shouldn't hurt anything. Timing is something you need to play with until you find where YOU like it. Some people like more top end (more timing) some people would rather have more low end power (less timing).
