Well, got my gifts and now can't decide...PODS vs. DDP4's
Postby eyoung429 » Fri Dec 28, 2007 8:43 am
Already have the 366 spring put in, working on the valet changeover. Bought a set of PODs prior to x-mas but opened up the gifts and my family bought me a set of DDP4's....
Anyone have experience with just the ground fuel pin, HX35 mounted in a reg cab dually????
Don't have to worry about the tranny....heads are ringed and have arp studs on a fresh mill. no porting, stocker cam, fuel screw in, cable kill.
1991 IC D350 2wd Dually,st cab, full 4in Magnaflow exhaust, 3.73 gears, auto 518,HX35....goin' to twins!!!
member of the cable pull club
eyoung429
Re: Well, got my gifts and now can't decide...PODS vs. DDP4'
Postby flashgordon » Fri Dec 28, 2007 10:14 am
eyoung429 wrote:Already have the 366 spring put in, working on the valet changeover. Bought a set of PODs prior to x-mas but opened up the gifts and my family bought me a set of DDP4's....
Put the ddp4's in and sell the POD's...............or vice a versa...........Probably could sell the ddp4's for more.........?
If i had both in my hand......ddp4's would go in.
Flash
flashgordon
Postby CumminsPride » Fri Dec 28, 2007 12:57 pm
If it's a driver> DDP4's
If it's a toy> POD's
The POD's will probably make as much power anyhow. But the ones I ran were nasty.
Wade
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby GLHS » Fri Dec 28, 2007 9:19 pm
Are they 4 or 5 hole DDP 4s. From what I understand the 4 holers are about 15-20 more horse than pods and the 5 holers are about 30-35 more than pods. Either of them will make more power and run cleaner than pods.
You get done o-ringing the block or just the head?
GLHS
Postby eyoung429 » Sat Dec 29, 2007 8:10 am
Head is o-ringed....not doing the block on this mill. Setting up another block for racing only that will be twins on freeze, that one will be fire-ringed.
This is the set that I received Part: #DDP 899355LPM. They are the 80hp ones, so I am guessing (due to lack of info on their webpage) that they are the 5 hole ones.
eyoung429
