Throttle Lever Fiber Washer
Postby Collers9640 » Fri Apr 15, 2016 2:07 pm
Anybody know where I can get another fiber washer (Correct One).
I'm talking about the reddish color one. I believe it sits on the index marks.
Thanks Matt
Collers9640
Re: Throttle Lever Fiber Washer
Postby thrashingcows » Sat Apr 16, 2016 2:07 am
Why not use a nylon washer? But would have to suggest cummins dealer for the part, if you can find a part number for it. ;)
thrashingcows
Postby CumminsPower59 » Mon Apr 18, 2016 6:49 am
If you are talking about the large plastic washer that is around the small metal one between the throttle levers, the part number is 1 460 113 301. It's called an Intermediate Disc by Bosch.
Item number 305...
http://www.dieseltruckresource.com/foru ... mp-231863/
