Valve spring reccomendations
Postby 79Powerwagon » Tue Apr 26, 2016 4:50 am
I know it's been beat to death but what's the consensus on valve springs?
I read 3k rpm, 4k, you need them. 60 lb, Hamilton's, etc.
Going to run 6x13 injectors, small twins, probably clipped 366 spring.
Are 60lb springs ok or will I need heavier?
79Powerwagon
Re: Valve spring reccomendations
Postby spencerdiesel » Tue Apr 26, 2016 6:56 am
Kinda like EGT's, there's some grey area when it comes to revs. How many miles are on the stockers, how much boost you will see etc. Because I can't take a seat under my valve cover and watch the action, I keep mine from going over 3300. I think higher boost lowers the safety margin on rpm, but I don't know how much.
If I ran heavier springs I'd add zinc additive to the oil to keep cam/tappet wear to a minimum. Do you need the zinc, probably not. But there's a lot more pressure over worn stock springs, and most modern emission oils don't have zinc and moly anymore.
H1C/18
Muffler delete
spencerdiesel
Postby 79Powerwagon » Tue Apr 26, 2016 7:54 am
I know I'll be running 50+ psi. Probably around 3500 rpm.
I'm not as worried about rpm as I am boost...
I did a Hamilton 188/220 cam, 103 springs, maxspool pushrods in my 04. Running zinc. That's a spendy little setup that I'd like to avoid if I can, safely.
79Powerwagon
Postby spencerdiesel » Tue Apr 26, 2016 9:20 am
3500 rpm & 50 psi? I think the 60 psi springs would be good insurance
H1C/18
Muffler delete
spencerdiesel
Postby 79Powerwagon » Tue Apr 26, 2016 9:53 am
I was under that impression until I started digging. Some guys say the 60lbs, some say at that psi they are not enough. Guess I'm wondering if anyone has had an issue.
79Powerwagon
Postby spencerdiesel » Tue Apr 26, 2016 1:22 pm
Hoping someone besides me (and with actual experience) will chime in. RC was running stock springs on his old 12v, it saw 50 psi and 3800 if I remember the dyno vid
H1C/18
Muffler delete
spencerdiesel
Postby DMan1198 » Wed Apr 27, 2016 2:33 pm
I know springs and pushrods make a difference all on their own on the 24v's, but my 165# valvesprings, and the rest of my valvetrain upgrades have sat in a box longer than I've owned my 4th gen.
Postby RCCUMMINS89 » Thu Apr 28, 2016 8:36 pm
On a factory cam, you'll be fine. Aftermarket cam, go with 165#.
On a side note, there is no notable gain in clipping a 366 spring. Depending on how it is done, it'll only decrease available fueling via the fuel screw
Postby 79Powerwagon » Fri Apr 29, 2016 5:32 am
Thanks RC!!
79Powerwagon
Postby Deathrod » Sat Apr 30, 2016 5:50 am
Ive never got around to changing mine out, ive pegged my 60 psi gauge out from time to time and haven't had an issue. That being said i try to not run that much boost cause i still have the stock springs.
Deathrod
