Gino's fuel line pressure buffer ?
Postby jethro » Sun May 01, 2016 11:47 pm
I see genos sells a tiny gizmo that goes after the fuelpump and claims to dampen out the "hammering" that
the pump pulsations cause the metal fuel delivery tubes feel----
Is this just to keep a fuel gauge from being "jumpy" -- or is there a problem with the 2-nd gen piston fuel pumps
fatigueing the metal lines ???????
Tim
jethro
Re: Gino's fuel line pressure buffer ?
Postby ellis93 » Mon May 02, 2016 5:47 am
The jumping of the guage needle kills the guage......no other harm to be had. You can do the same thing with a needle valve from the hardware store.
