IP slide pin leak?
IP slide pin leak?
Postby theoldmanW350 » Thu Jun 16, 2016 7:06 pm
Hello all been awhile since i've been on the boards. Today I re-installed my original fuel pin and did the 90* CW turn but what did I find? diesel inside the pump. The fuel pin I removed was the M2 from M&H which isn't too of an aggressive pin. Slide pin o-ring leak is my first thought. That's a disassemble job correct? Thoughts?
1990 W350. Getrag overfilled. Stock fuel. Stock turbo. M2 fuel pin. Hungry Diesel HVLP lift pump, 2nd gen IC w/ 3" Pusher Intake. Air bag set-up, onboard air. BD exhaust brake. Almost all 4" exhaust. Autometer's. Upgrades as money allows.
theoldmanW350
Re: IP slide pin leak?
Postby ellis93 » Thu Jun 16, 2016 8:12 pm
I'd dry the bore out and run the factory pin,to see if it does it again.
If your patient,you can install that oring with the pump in place. You'll need to remove the throttle lever assembly and have a small pair of needle nose pliers. You remove the pin and then you'll see the oring. It'll be sandwiched between a (I don't really know what to call it) cap and the housing. That "cap" has a place for an Allen wrench,couple of turns and its out and the oring is easily removed.
Postby theoldmanW350 » Thu Jun 16, 2016 9:03 pm
copy that. i did dry it out so i'll recheck tomorrow. thanks ellis
theoldmanW350
Postby PToombs » Fri Jun 17, 2016 4:57 pm
Turning it 90* is kind of deceptive. That's what people say to do, but what you actually want is the deepest side of the cone towards the front, and it may not be 90*.
IIRC you need to remove the fulcrum lever shaft to get to the fuel pin. I'd pull the pump top and then remove the shaft, then the "cap" as Ellis called it. I can't remember what the correct name for it is.
Postby ellis93 » Fri Jun 17, 2016 6:36 pm
Schit! I forgot about that! I'll be danged if I didn't soil the tread with misinformation.
One I tore down....maybe it'll help.
viewtopic.php?f=1&t=16417&hilit=A+moron
Postby PToombs » Sat Jun 18, 2016 3:54 pm
That's ok bud, we're used to you soiling something. :lol:
There's not many good pics of that part of the pump top in that thread, I just went and scanned the whole page.
Postby ellis93 » Sat Jun 18, 2016 6:47 pm
PToombs wrote:That's ok bud, we're used to you soiling something. :lol:
That's why I said "maybe" it would help......
Postby PToombs » Sun Jun 19, 2016 4:50 pm
It was a good plan........
