acc. linkage source ?
Postby jethro » Fri Jun 17, 2016 11:53 pm
Somewhere----- about 6 months ago I remeber running across an ad for an aftermarket throttle linkage
with the snap-on ball ends. i think it was all metal. I see mine has a crack in the plastic base where the rod
screws into it. Still working but would like a better one maybe...... prevent future failure....
Does anyone remember where I saw that ???????? (I remember chrysler had a rebuild kit--- but that wasnt it)
Tim
jethro
Re: acc. linkage source ?
Postby PToombs » Sat Jun 18, 2016 3:46 pm
There is a kit available from cummins, it's an upgrade kit with metal ends. A search should give you a part number, or maybe somebody who knows it will chime in.
Edit;
A quick search turned it right up,
Kit is 4089076, includes rod, two nuts and two ends. Ends separately are 3990093 and 3990094.
Postby jethro » Mon Jun 20, 2016 12:02 pm
Great ! Thanks PT !
I will check with our local freightliner dealer on that part ! All metal sounds good !
Tim
jethro
Postby PToombs » Mon Jun 20, 2016 4:28 pm
Tim, you can check e-bay or Amazon, it's on there too.
