setting valve lash
setting valve lash
Postby DodgeFreak » Mon Jun 27, 2016 12:17 pm
I've always just use the alt. Nut and rolled the engine over but I believe it rolls the engine backwards. I always figured if the adjusters are loose and the cam lobes are on the bottom it doesn't matter. Am I correct or should I roll it over the right way? I haven't had any engine failures yet lol.
Re: setting valve lash
Postby stuffy » Mon Jun 27, 2016 3:26 pm
I don't think you'll have a problem. Myself and lots of others do it that way. It's way easier than using the barring tool
92 w250
Silver Bullet, pump maxed, full manual 47re, 5x18s, Hungry Diesel piston pump
stuffy
Postby DodgeFreak » Tue Jun 28, 2016 11:34 am
Will valve lash affect fuel mileage with out being to far out?? Seems to run fine but I want to try and squeeze any mileage out that i can.
Postby stuffy » Tue Jun 28, 2016 4:51 pm
In theory it could I suppose. I set mine to .008 and .018. Only thing I noticed was an egt drop of about 50 degrees
92 w250
stuffy
