BIG C wrote:I will be replacing the injectors in my late 91 inter cooled 5.9 ctd powered w250.
Three of the injectors appear to have been replaced or rebuilt.
What or how big of injectors can be put into a truck that has not had head work, or a bigger turbo put on?
The truck does have a 4" straight exhaust, I believe the pump has been 'turned up' a little it has gauges, and a large air filter(stock?)
and stock intake.
thanks for your reply..
CumminsPride wrote:I would say bosch 190's or just a 30-40HP injector of your choice. With a carefully tuned pump you could get by with some 370's just watch your guages. A valet would also be a good choice with bigger sticks. A Stage IV compressor would help with the EGT's too. Oh, CONVERTER, CONVERTER, CONVERTER will help with your authority!!
Wade
bgbubabrwn wrote:Would an hx35 be considered an upgrade over the stock turbo? and what are valets?
