VE governor spring question, 411?
Postby toomanys10s » Mon Oct 10, 2016 8:05 pm
I recently purchased a industrial ve pump for 6bt. Cummins part # 4933531 150hp/443ft lbs. I pulled the LDA housing off to check internals as its new old stock, making sure there won't be any surprise runaways.. The pump has a governor spring marked with 411. What spring is this?
2004 cummins swapped excursion
2007 f350 zf6 soon to be cummins powered
1999 f250 zf6 in the process of being cummins powered (have all the parts, looking for the time!)
1982 Volvo 242 D24T- 2.4 inline six turbo diesel, factory redline 5,200rpm with a VE pump.
toomanys10s
Re: VE governor spring question, 411?
Postby spencerdiesel » Thu Oct 13, 2016 1:54 pm
I tried finding that using what I assume would be the whole part # 1464650411 and didn't have any luck. My guess though is that a 6bt rated for 150 hp and a high torque to hp ratio wouldn't have a very high governed speed....
H1C/18
Muffler delete
spencerdiesel
