Trying to revive my 91'
Postby meby » Sat Feb 18, 2017 3:02 pm
I'm trying to revive my 91'. I can't get it to fire. It's been sitting for two years. I've installed a low pressure piston pump since the primer on the original didn't work. I pop tested all six injectors. 220 to 230 bar on all with clean spray patterns. I can hear the shut-off solenoid click.
What am I missing?
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Re: Trying to revive my 91'
Postby PToombs » Sat Feb 18, 2017 5:49 pm
Do you have a good battery so it spins over good? Primed it to the IP? Crack all 6 injectors open to bleed it out? It should go.
It might also be sucking air before the LP. If you don't have a good spray of fuel at the injectors, remove the FSS plunger just to be sure it's not that.
Postby meby » Sat Feb 18, 2017 6:00 pm
As far as I can tell the pump is primer properly. I cracked all six injectors. Do you know if it's possible for the fss to click and the plunger not open?
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby PToombs » Sun Feb 19, 2017 6:28 pm
It could be, I guess. It could click when it opens and bounce back closed. I would think if it has enough power to open it would stay open. Maybe check voltage to the FSS? check right on the stud itself, not the wire.
Postby meby » Mon Feb 20, 2017 6:38 am
It's alive! I had indexed the throttle wrong when I resealed the top and the power screw wasn't in far enough.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby meby » Mon Feb 20, 2017 6:40 am
Hey, it let me post anybody else have problems?
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby PToombs » Mon Feb 20, 2017 6:34 pm
Working fine for me, 12 hours later. :lol:
Glad you got it, sometimes the simple things..... ya know?
