Won't start after sitting 2 years
Postby dchelette » Sun Feb 19, 2017 8:54 am
I acquired a 93 with a 5 speed, so I parked the 92 with AT. Now its time to put the 92 on the market, it's been sitting for 2 years. Replaced fuel filter and lift pump. Primed IP and bled injectors, squirting good at injectors. When starter is engaged it fires for a second, then quits. Every time I try it fires for that second then nothing. Because it fires, the starter will disengage and you can't keep cranking. Any help, ideas, information is greatly welcome.
Thanks,
92 D350 DRW Auto Pump tweaked Open air filter
197K
dchelette
Re: Won't start after sitting 2 years
Postby stuffy » Sun Feb 19, 2017 4:19 pm
Try giving it some throttle while starting. Or try some ether
92 w250
Silver Bullet, pump maxed, full manual 47re, 5x18s, Hungry Diesel piston pump
stuffy
Postby dchelette » Sun Feb 19, 2017 4:39 pm
Done and done, no help. Fires for that first second, then quits. Getting frustrated.
Thanks,
197K
dchelette
Postby dchelette » Mon Feb 20, 2017 5:23 am
Is there a check valve between tank and lift pump? Can I blow back from lift pump to tank?
197K
dchelette
Postby Philip » Mon Feb 20, 2017 6:49 am
No check valve.
Are you seeing high pressure fuel at the injectors when bleeding or just fuel with bubbles in it?
Are you bleeding while spinning the engine over?
Postby dchelette » Mon Feb 20, 2017 6:55 am
Have good pressure at injectors (squirting up to hood), while cranking. Tighten injector lines and it hits immediately, but dies that fast. I'm thinking plugged filter/strainer on tank pickup? Pulled return line and operated manual lever on pump, was not impressed with the amount of fuel coming out.
197K
dchelette
Postby stuffy » Mon Feb 20, 2017 7:21 am
If you get air every time you bleed injectors I bet one of them is stuck open. If you have some known good ones swap them in or take the lines off and put some fuel in the top of the injectors. Crank it over and whichever one squirts the fuel back out is stuck
92 w250
stuffy
Postby absentheart » Wed Mar 08, 2017 10:16 pm
If I get a big air bubble in my 93 no amount of bleeding helps, I have to pull the heater grid grounds and run it on ether for a few seconds to get the air out and it runs like nothing happened.
1993 D-250; NV4500 plus US Gear "Dual Range," my poorman's 10 speed; Cable Shutdown Club; Full Power Screw Bottomed; Denny-T Fuel Pin; Hungry Diesel AFC Spring; 1/8" Timing Bump; 12cm Non-wastegate housing; Unbranded exhaust brake.
absentheart
