Throttle rod ends
Throttle rod ends
Postby needlenose » Thu May 11, 2017 7:12 pm
I know the rod end topic has been around many times already, but I can't seem to find a solid answer.
Will P7100 rod ends work on a VE? They seem to be much more readily available as a single piece.
Thanks!
needlenose
Re: Throttle rod ends
Postby Remps » Thu May 11, 2017 10:27 pm
I have 2nd gen metal ends on one of my 1st gens, don't remember which one. I got the ends and a 2nd gen throttle cable from dodge for 24$ iirc. Much sturdier than the plastic 1st gen ends.
Postby DodgeFreak » Thu May 11, 2017 10:52 pm
I believe you can get the rod ends through cummins yet. I think Pete or Eric has/had the part numbers.
Postby PToombs » Sat May 13, 2017 6:37 am
The new ones are all metal, dodge or cummins or whoever updated them and did away with the plastic. I did a quick search here and came up with a number, the kit is 4089076 and just the ends are 3990093 and 3990094.
