Need Help Replacing Head gasket
Postby Collers9640 » Thu Jun 01, 2017 6:13 pm
My Head gasket started leaking the other day and needs replaced.
Im a scared to remove the head because the last time I removed a cummins head I thought I had drained out all the coolant but to my surprise when I pulled the head, coolant drained into the cylinders. Thankfully i only needed the short block was junk anyways.
So is there a way to ensure all the coolant has been drained? Like a port to pressurize or something?
Collers9640
Re: Need Help Replacing Head gasket
Postby ellis93 » Thu Jun 01, 2017 7:07 pm
I've always just took the lower hose off the radiator and that was enough.
I little coolant in the cylinder won't hurt a thing.....just wipe it out.
Postby DodgeFreak » Thu Jun 01, 2017 7:14 pm
ellis93 wrote:I've always just took the lower hose off the radiator and that was enough.
clean out the cylinders and change the oil. We change the oil anytime the head is off an engine. Doesn't matter if there is a lot of antifreeze that goes in the cylinder or a little, if you clean it out you will be fine. depending on how much is in the cylinder sometimes after I've cleaned them out I will wipe the cylinder walls down with oil and roll the engine over to make sure the cyl. isn't going to be a dry start. then put the head on.
Postby Collers9640 » Fri Jul 07, 2017 10:04 pm
Im finally about to replace the gasket thanks for the help
Collers9640
