Fuel shut off solenoid fixes!!
Postby kyled19 » Sun Aug 27, 2017 1:11 am
Ok so I have been going through fuel shut off solenoid like crazy and I'm wondering what I can do to help get more life out of them! So I have my pump pretty much maxed with an he351cw and stock injectors. I have read bigger injectors would help. If this is the case what is a good injector to go too? I have a fass lift pump as well with a Denny t stage 2 and a 3200 gov spring. I don't want to go to a mechanical shut off if possible but I also don't want to worry about my shut off solenoid failing every time I drive the truck. All info appreciated!
93 d350 extened cab dually dennyt stage 2, 3200 rpm gov spring, intake, 4 inch exhaust, he351cw, fass lift pump, and an a518. 4th gen seats
kyled19
Re: Fuel shut off solenoid fixes!!
Postby BC847 » Sun Aug 27, 2017 6:23 am
This will, or will not work for you. I've been running like this for five or so years . . . . https://www.dieseltruckresource.com/for ... id-117593/
Postby 1STGENFARMBOY » Tue Sep 05, 2017 11:27 am
Me to.
