I Need a stock 89-93 lift pump fuel line
Postby Collers9640 » Sat Sep 23, 2017 11:58 am
Does anyone have an extra lift pump fuel line laying around they would sell?
Collers9640
Re: I Need a stock 89-93 lift pump fuel line
Postby Begle1 » Mon Nov 06, 2017 2:09 pm
I imagine you've found your line? I probably have one in my garage I'll be getting back to in December.
This is from the pump up to the filter head?
Postby laneends » Tue May 29, 2018 11:46 pm
Still need one?
1990 D-250 with getrag 360: pyro, boost, volt, oil pressure, fuel pressure, and water temp gauges, hot screw, 366 gov spring, THD pin, M&H dynamic timing spacer, throttle linkage adjusted for full travel, 4" turbo back exhaust, THD's LPPLP, BHAF, south bend clutch. THD 5x13 comps, 362sxe, 3" crossover, pump to the head
laneends
