Finally to truck out but it has not Power!!!!!
Postby Collers9640 » Thu Nov 02, 2017 6:21 am
Ok so after I fixed every other problem with my truck I took it out for a drive and now the truck has no power, frustration is setting in.
I have already turned the pump up so I know that’s not it.
The motor Will Rev up but there is no power behind the rpms. It feels like it just stops fueling at about 1/4 throttle.
Is it possible the fuel pin could be stuck or something? The motor sat for a while but the pump is a fresh rebuild and was done professional and put on a flow bench so I’m at a loss..
Any Ideas
Collers9640
Re: Finally to truck out but it has not Power!!!!!
Postby CumminsPower59 » Thu Nov 02, 2017 9:19 am
How is the fuel supply? Got a pressure gauge on it somewhere after the lift pump? Sounds like it's not getting enough fuel.
Postby Pausma » Thu Nov 02, 2017 9:51 am
x2 on fuel pressure
could try a new fuel filter also, simple things first!
91 D350, adjusted fuel pump, custom exhaust, pyro, tach and boost gauges
2001 2500 4x4 stage 2 afe intake, custom exhaust, edge insight
06 VW jetta tdi 5 speed, custom exhaust, egr blockoff, 1.5 malone tune
Pausma
Postby Remps » Thu Nov 02, 2017 11:38 am
I'd try lubing the horizontal pin that rides on the fuel pin as well, if it's stuck in a dry o-ring it could cause the exact issues you're having. Put a little grease on the fuel pin as well so you can see if the horizontal pin leaves a track. It's good preventative maintenance to lube the o-ring where the afc line connects to the cylinder head as well, while you're pulling the pump top off.Tightening and loosening a dry 25 yr old o-ring repeatedly can cause them to crack. Which can potentially cause further issues.
Postby Gots_a_sol » Thu Nov 02, 2017 2:52 pm
Make sure you have the correct banjo bolt on the return outlet of the pump. The proper one has a tiny orifice to restrict flow.
-Joe
Gots_a_sol
Postby Collers9640 » Fri Nov 03, 2017 3:26 pm
Lift pump and fuel filter are brand new
Collers9640
Postby Collers9640 » Fri Nov 03, 2017 3:28 pm
Do you have a pic of the correct banjo bolt?
Collers9640
Postby Gots_a_sol » Fri Nov 03, 2017 4:32 pm
-Joe
Gots_a_sol
Postby Collers9640 » Sat Nov 04, 2017 8:50 pm
- I verified that I have the correct banjo bolt on the return line.
- I have a new lift pump installed
- I have a new fuel filter installed
I still have to check the fuel Pin.
Does anyone have any more ideas or things I can check.
Collers9640
