VE Pump Control valve oring seal question
Postby rustybottoms88 » Sat Nov 18, 2017 6:23 am
Are specific seals in the Bosch DGK121 kit that go on the control valve? I found two sets of three seals that were similar OD but different thickness. I put the thinner seals on and it's leaking. I plan to take it apart and see what's up but thought I would check and see if I could round up more info. Any help is appreciated.
rustybottoms88
Re: VE Pump Control valve oring seal question
Postby thrashingcows » Sat Nov 18, 2017 5:36 pm
I have never measured them, just remove them and find ones in the pack that look as close as possible, never had a leak.
thrashingcows
