Can anybody sell me a timing gear? I cracked mine.
Postby Begle1 » Tue Jan 09, 2018 9:40 pm
https://photos.app.goo.gl/XxyPrfn9xNXShmpH2
I need a timing gear, I dropped and cracked mine.
Anybody got one for sale?
Thanks.
Re: Can anybody sell me a timing gear? I cracked mine.
Postby ellis93 » Wed Jan 10, 2018 10:55 am
I'll look and see if I have one.
Postby ellis93 » Fri Jan 12, 2018 2:03 pm
No dice. What I have is the cracked one from the dodge.
Postby Begle1 » Sun Jan 14, 2018 2:06 pm
Are cracks on this gear common?
Postby ellis93 » Sun Jan 14, 2018 5:21 pm
When I found mine cracked there were a few said they'd experienced the same. I was told by a few to run it.....I didn't tho lol. I believe I bought my replacement from eBay and then I bought another and a ve timing case/cover off of someone here for my 24v C10.
Postby PToombs » Sun Jan 14, 2018 5:24 pm
Yes and no, it doesn't happen a lot, but it happens. I doubt if you cracked yours from dropping it also. I think the biggest cause is over torqueing them, wedging it too hard on the tapered shaft, then all of a sudden it cracks.
Postby ellis93 » Sun Jan 14, 2018 5:25 pm
Postby Begle1 » Sun Jan 14, 2018 11:58 pm
You know Pete, over-torquing makes sense to me. The torque spec in the book for the gear is very low, something measured in inch-pounds, which is weird for a nut that size.
I dropped mine from maybe two feet up, I didn't think I cracked it at the time, until I noticed it was cracked all the way through a few days latter.
Probably safe to say that nobody has ever heard of catastrophic timing gear failure?
A few guys have PM'd me, I'll be buying one this week.
Postby PToombs » Mon Jan 15, 2018 5:36 pm
48 ft lbs. Real easy to over torque that, I used to just tighten it up, but I am getting smarter as I get older and use the torque wrench to prevent what happened to you. ;)
