Towing MPG Thread
Towing MPG Thread
Postby VMacKenzie » Sun Jan 06, 2008 7:57 pm
OK KTA did his ultimate MPG thread, how about a towing MPG thread.
State truck config/trans, type and weight of load, speed towed at, RPM, and conditions (type of highway, headwind, etc) and any other pertinent details :)
Vaughn
'98 3/4T CC shortbed 4x2 12v
'96 3/4T CC 4x4
VMacKenzie
Re: Towing MPG Thread
Postby flashgordon » Sun Jan 06, 2008 11:00 pm
VMacKenzie wrote:OK KTA did his ultimate MPG thread, how about a towing MPG thread.
Vaughn
15 MPG, 18' flat bed trailer, 93 honda Civic. 85 mph most of the time.........Every thing you see in my sign Below........The Gear Vender Overdrive had most to do with it w/4:10 Gears
Flash
flashgordon
Postby JD730 » Mon Jan 07, 2008 1:58 pm
12.5MPG, 93, club cab, 47RH, POD's, 96 dodge club cab CTD, puts GCWR somewhere between 18 and 19k lbs. 65 to 75MPH on rollings hills coming down rt 81 out of NY. This is the trip that cooked my trans front clutch, wouldn't find out till much later.
Mike
The "Rattle Box"
JD730
Postby oldestof11 » Mon Jan 07, 2008 4:13 pm
1993 W250 5 spd, 4.10's, 24ft GN Keifer Bilt.
The trailer had the flooring replaced with SOLID OAK custom cut 3"x8". Took a load of shingles to New Orleans. Probably weighed about/close to 20K combined. 70mph the whole way. Up and down hills, head winds, tail winds, rain, fog, almost no visibility to sweltering 80*. Got 12 mpg down and 14 on the way back minus the shingles.
Mods, 3200 rpm spring (life saver!), swiss cheesed air box, open 3" exhaust to 6" stacks, stock tires.
Postby GO OVRIT » Mon Jan 07, 2008 8:51 pm
My 93 5spd with 2.5 turns on the fuel screw and straight piped got 13.5 towing my jeep and 20' tilt deck through the mountains. I was running between 75 and 35 depending on the grades and saw a peak of 1400 on the guage. Oh and that was with 37" tires. :grin:
GO OVRIT
Postby Philip » Mon Jan 07, 2008 10:42 pm
93 W350 dually,518 auto, 3:08 gears, load was a 73 Olds Cutless on a tandem trailer. Weight was around 7k for a gross of 14k. Cruise set at 70MPH. I didn't have a tach at that time. All fuel stops hand figured came out at 13 MPG. This was from south of Tulsa to Peru, IN total milage was 775.
I made a total of three trips loaded with varis items. All three trips were 13 MPG loaded. All loads were in the gross range of 13 to 14k.
Going down empty I ran 18 MPG at 80 MPH all three times.
Postby SChandler » Tue Jan 08, 2008 12:49 pm
Towed my dad's 93 Chevy pickup on a flatbed trailer with my 92. With three of us in the cab and bricks and sandbags in the bed for traction gross weight was approx. 16k. Towed up and down hills (a couple 6% grades), speed varied between 30 and 55 due to snow and ice on the roads (never got out of 4th gear). I got 15.4 on that tank with 200mi towing and the rest regular highway driving. EGT's never went over 1050.
Edit: That's with 3.54 gears.
SChandler
Postby KTA » Tue Jan 08, 2008 9:45 pm
1993 W350 370injectors, pump maxed, 4" exhaust, hx40/16 23000lbs gross, 70-75mph, 3.54gear, nv4500, 10mpg.
Postby dpuckett » Wed Jan 09, 2008 3:59 pm
1993 D350 C&C steel flatbed Getrag and 3.54. 1-2 turns of fuel screw, H1C/18, straight pipe, AFC tinkering, timing bump. stock injectors. Haluing hay in '02.
Loaded GCVW of 23-24K. Averaged 13-14mpg, depending on wind. Averaged 65mph, 5th gear.
Empty truck and trailer (20ft car hauler), 9200#GW, 18.5mpg.
Empty truck- 19mpg.
Postby VMacKenzie » Tue Mar 04, 2008 11:10 pm
Thanks for the info. I was interested to see how you guys compared to my 2nd Gen 12V trucks. . . overall looks like you all are getting a little better MPG towing than I do with either of my trucks ('96 4x4CC 5-speed and '98 4x2CC auto). Both get around 13 towing a light travel trailer, ~15 towing a flatbed with a car loaded on doing highway speeds (65).
Vaughn
'96 3/4T CC 4x4
VMacKenzie
Postby MunK » Wed Mar 05, 2008 5:11 am
1992 W350/5spd Wis-Nebraska. 24' enclosed car hauler loaded with furniture when we moved. 65 mph mpg in the 10-13mpg range. Figured out latter (after blowing 3 tires in 500 miles) that maybe the trailer was loaded a little heavy.
Next trip... smaller load.. 15mpg, same route, same truck, same speeds.
Same truck,empty trailer,70 mph it managed 15.2.
Last trip... 10.7 average...REAL heavy. Getrag died...hooked trailer to motorhome..(ugh) and managed to achieve a all time low of 4mpg at 55mph in camper. (the next 6bt swap)
NoRM
91 W250 Nv4500/3.55
85 W350 Crew Cab (soon to be a 6bt/Nv 4500)
MunK
Postby CAJUN 93 » Wed Mar 05, 2008 9:51 am
my truck in sig minus 4" straight exh (stock exh at the time ) with 20' open car trailer. covington, la to ft walton empty trailer- ft walton to sulphur, la with member tomtom's d250 on trailer and back to covington, la empty trailer. average 16.2 for entire 886 mile trip. that was one FUN weekend :D .
daryl
CAJUN 93
Postby greasemonkey » Wed Mar 05, 2008 12:26 pm
I may be obsessive about some things, so I cleaned it up into a list so it's easier to scan through.
Truck Config/Trans: sig
Tires: 285/75-16 Dueler AT's
Load Wt: ~14k(contractor body 3500HD chevy on a GN)
Approx. speed: 50-65
RPM: 1700-2000
Terrain: up/down a 6% grade 40 miles, valley floor; 400 mi round trip
any other pertinent details: California has a 55mph speed limit for anything with a trailer.
Mileage: 15 mpg
Tires: 305/70-16 procomp x-terrains (horrible anywhere near pavement)
Load Wt: typical- 5-7k, car/LT on a bumper pull 22ft flatbed
Approx. speed: 55
RPM: 1900
Terrain: flat for a few hundred miles, road might curve or veer every 5 miles or so, random stop signs or towns/city.
any other pertinent details: CA is retarded, requiring a 55mph speed for trailers.
Mileage: 17...only good thing about the low speed limit! that number makes the pwrstroke guys mad, they can't get that empty driving like gramps.
if you're lazy, just copy/paste that...
Truck Config/Trans:
Tires:
Load Wt:
Approx. speed:
RPM:
Terrain:
Mileage:
'93 250 4x4 NV4500, flatbed, club cab, ex brake, pump tweaked, too many new ideas thanks to you guys.
dubbed the "Mexican Mtn Goat"
..if you find yourself in a fair fight you did not properly prepare..
..hot rodders are the original recyclers!..
greasemonkey
Postby SChandler » Wed Mar 05, 2008 1:27 pm
greasemonkey wrote:Mileage: 17...only good thing about the low speed limit! that number makes the pwrstroke guys mad, they can't get that empty driving like gramps.
I gave my dad a bad time about that. I got the same fuel mileage towing his truck (93 Chevy extended cab with 6.5L diesel) as he gets driving it empty. :thumleft:
SChandler
Postby 1tondodge » Wed Jul 09, 2008 6:03 pm
little old thread but...
I got 17 mpg towing my fat pig of a jeep on an open car trailer back from Bend Or recently, plus going up and over the cascades, around 6.5k total with all the other crap I was hauling. I was pretty pleased but I didnt go over 63 mph. I wished the truck didnt have 410s so I could tow a little faster and still get decent milage.
92 D350 5 speed - HX35, fuel screw cranked and pump tweaked, 4" turbo back exhaust and gauges
92 Jeep YJ - Dual 35 spline D60's, 39" Krawlers, and some deep gearing
1tondodge
