Vacuum pump bearing
Vacuum pump bearing
Postby meby » Sat Aug 25, 2018 1:33 pm
does anyone know if the early style vacuum pump bearing is still available? I have mine apart to replace the power steering pump and the bearing has more play than is healthy.
thanks
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Re: Vacuum pump bearing
Postby DMan1198 » Sun Sep 02, 2018 7:34 pm
It is no longer available from dodge, however there is a bearing that matches its dimensions out there. I had to do just that this year on a customers truck.
Postby meby » Wed Sep 05, 2018 5:55 pm
Found one through autovalue. Thanks
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby Donkey Kong » Fri Sep 21, 2018 2:59 pm
Also Gould Gear can supply rebuilt pumps and parts.
Darth Cummins 93 CC W250 NV4500 HX35 350hp 37s 1.5T leafs...its stiff
Donkey Kong
Postby thrashingcows » Wed Sep 26, 2018 11:05 pm
My bearing was making a tinging sounds years ago on my 89 motor,so I swapped to the 91.5-2000 Vacuum/PS system, have never regretted it. ;)
thrashingcows
