Truck won’t start
Truck won’t start
Postby 92cummins89 » Thu Nov 08, 2018 3:49 pm
Was doin the fuel heater delete put everything back together an now when I go to turn it on nothing
Lights won’t turn on when I turn the key the gauges move but not the volt gauge any ideas checked relays an fuses all are good, checked the fuel cylinder cut off an it’s good any ideas ??
92cummins89
Re: Truck won’t start
Postby 92cummins89 » Thu Nov 08, 2018 8:18 pm
Any help ?
92cummins89
Postby 92cummins89 » Fri Nov 09, 2018 2:43 pm
Any body ?
92cummins89
Postby PToombs » Fri Nov 09, 2018 2:50 pm
Start with battery connections and then see if everything in the fuse box has power. If not, a fusible link probably burned up. Also check the 2 wire plug near the battery, that supplies power to the activator on the starter. You may have knocked it loose doing the filter.
Postby 92cummins89 » Fri Nov 09, 2018 5:49 pm
I finally got it to start no fusible links I put in a fuse block ...but here’s what’s weird in order to start it have to to jump the starter straight to the battery, some times ... now my lights flicker driving down the road an my gauges are not reading there just bouncing back an forth, an no my brake peddle is hard
Everything was normal an fine yesterday morning
92cummins89
Postby cougar » Sun Nov 11, 2018 8:51 am
At the back of the engine on the left side are 2 large connectors, a black one and a gray one. What you have described has to do with that black connector. Unplug it and reseat it, see if that helps.
01 2500 "the work truck".
cougar
Postby 92cummins89 » Sun Nov 11, 2018 5:26 pm
What do those connection control?
92cummins89
Postby cougar » Mon Nov 12, 2018 8:19 am
Those 2 connectors are the main interface between the engine, transmission and the body. Disconnecting the fuel heater could have disturbed that connector. The same one the starter is wired through along with the fuel solenoid.
cougar
Postby 92cummins89 » Wed Nov 14, 2018 7:15 pm
Ahh good deal thanks
92cummins89
