TOPHAT VALVE STEM SEALS
Postby wilkyflex » Sun Feb 24, 2019 10:32 pm
4 OF THE 12 valve stem seals slipped and were riding up the stems, thus causing oil burning and blue smoke.
Does anyone know where I can get the tophat style seals that will fit the old style 1992 cummins head?
I know I can buy the top hat seals that fit the new style head and 94-98 cummins, but they say it requires machining to get the seals to fit.
Does anyone know exactly what machining is required to make the seals fit?
Thanks
Dean
805-628-6221
wilkyflex
Re: TOPHAT VALVE STEM SEALS
Postby spencerdiesel » Mon Feb 25, 2019 6:24 pm
Did some brief searching and it seems like the machining is required to run the top hat style. The good part is this particular "machining" seems to be a simple single cut per int/ exh. I read multiple forum posts stating it cost from $50 to $100 to have the machine work done.
H1C/18
Muffler delete
spencerdiesel
