justagoodolboy wrote:Another thing I noticed as it does not seem to smoke as much as it used too. I was under the impression boost leaks would create more smoke. Am I correct?
PToombs wrote:You should get a boost gauge on there. Then you can see if you are losing boost, or at least keep track of it. My guess is a boost leak that's bad enough to not move the pin.
If you have a fuel problem, it's after where the gauge is plumbed in. If the line from the tank was collapsed, you would lose pressure.
CumminsPride wrote:Could the clutch be slipping? Never had a G-Trag so I have no clue what their tell tale signs are.
Wade
PToombs wrote:CumminsPride wrote:Could the clutch be slipping? Never had a G-Trag so I have no clue what their tell tale signs are.
Wade
Signs? The engine going rrrrrrrrrrrrrrrrrrrrrrrrr![]()
PToombs wrote:Signs? The engine going rrrrrrrrrrrrrrrrrrrrrrrrr![]()
