Dip stick o-ring? Is there one?
Postby Justgosurfin » Fri Dec 13, 2019 3:04 pm
Is there meant to be an o ring at the handle?
Thanks
1995 Ford E350
‘90 12v
Dana60-NV4500- NV271-10.5
2nd gen IC
THD Pin and HVLP
3200 spring
Timing spacer
370 injectors
Justgosurfin
Re: Dip stick o-ring? Is there one?
Postby PToombs » Sat Dec 14, 2019 5:33 pm
Nope, just seals by that cap on it.
Postby Justgosurfin » Sun Dec 15, 2019 9:18 am
Well dang. I got a case of some blowby
1995 Ford E350
‘90 12v
2nd gen IC
THD Pin and HVLP
3200 spring
Timing spacer
370 injectors
Justgosurfin
Postby PToombs » Sun Dec 15, 2019 2:05 pm
Take the filler cap off while it's running (don't mind the funny whirring noise) and see how much it's blowing out.
Another thought, if you have a vacuum leak in the AC system or brake booster it will have excess blowby. The vacuum pump exhausts thru the crankcase to help purge fumes.
Postby BC847 » Sun Dec 15, 2019 8:14 pm
Make sure the crankcase vent hose isn't crushed where it runs between the starter and block. ;)
Postby Justgosurfin » Mon Dec 16, 2019 6:24 am
PToombs wrote:Take the filler cap off while it's running (don't mind the funny whirring noise) and see how much it's blowing out.
Did this once before and it was hard to tell if it was bouncing around just from vibration or gases. I’ll get a video this week. Do I have to be using a computer to add a photo or video file?
1995 Ford E350
‘90 12v
2nd gen IC
THD Pin and HVLP
3200 spring
Timing spacer
370 injectors
Justgosurfin
Postby PToombs » Mon Dec 16, 2019 4:40 pm
You need a photo hosting site like Photobucket or Imgur. I haven't posted a pic in a couple years so I'm not up on the procedure.
