Hot Wired
Hot Wired
Postby lazyjoe » Sun Jan 13, 2008 9:28 am
A friend of mine has a 91, 3/4 ton, 5 speed, 4/4. A couple of weeks ago it would'nt start unless he put a hot-wire to the injector pump. When it warmed up he could take the wire off, and it would start fine. Now he has to leave it on all the time, when he wants it to run. And take it off to kill it. Is there a relay some where?
lazyjoe
Postby cummins king » Sun Jan 13, 2008 12:58 pm
tha would be the shot of silinoyed he probaly broke it witch is not hard to do on a not stock pump
join the pull cable club or get a new shot off silinoyed, but theres know sence unless your no going to do any other monds
oh wait i didnt read that right were did you put the hot wire on the ksb or the shot off sylinoyed
93 4X4 auto
cummins king
Postby lazyjoe » Tue Jan 15, 2008 8:03 am
On the shut-off. He says now he can take it off when it warms up, and it's fine. Or if the temp. outside is above 50 it works ok.
lazyjoe
Postby flashgordon » Tue Jan 15, 2008 10:31 am
lazyjoe wrote:On the shut-off. He says now he can take it off when it warms up, and it's fine. Or if the temp. outside is above 50 it works ok.
Is it possible the ksb and that shut off are crossed..........????????No then it would start and then die when the KSB shut off.?????
Flash.
flashgordon
Postby cummins king » Tue Jan 15, 2008 4:39 pm
ksb only increases the timing
sounds more like a falty wire
93 4X4 auto
cummins king
