3200 SPRING
3200 SPRING
Postby OLDEARL93 » Sun Jan 13, 2008 11:11 pm
BEEN HEARING ALOT ABOUT THE 3200 SPRING .WELL I'M ALL EARS AND HOW DO YOU MATCH IT WITH MODS, DO YOU HAVE TO HAVE MODS TO INSTALL THE SPRING ,IS IT A GOVERNOR SPRING ONLY OR DOES IT SERVE ANOTHER PURPOSE
93 4X4 EXTRA CAB 5 SP. GERT.EGT,BOOST ,RPM GAUGE,TIMMING AD,PUMP TWEEKED,NEW HX35,REST STOCK
OLDEARL93
Postby CumminsPride » Mon Jan 14, 2008 5:29 am
You do not need any mods to enjoy the benefits of the spring. It's duty is a fueling governor. Stock defueled at approximatley 2350rpm on my truck and now more like 3100rpm.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby GO OVRIT » Mon Jan 14, 2008 9:47 pm
Just ordered mine today.
GO OVRIT
Postby OLDEARL93 » Sat Jan 26, 2008 9:02 pm
IS THERE ANY SITES WHERE I CAN SEE THE PROCEE TO CHANGE THE SPRING
OLDEARL93
Postby cummins king » Sat Jan 26, 2008 10:42 pm
http://dens-site.net/Dodge_CTD/Gover...ing/index.html
hope this helps, insteat of holding the top hat and spring and using plyers to remove the spring, just pull the trotle shaft out of the pump top much easyer, its not a big deal you can have it done in 30 mins for first timmer and 10mins after that, just make sure you mark the groves were the shaft and the throlte are or just make sure you have sombody ready to shot the truck off lol
your going to like the mod
hey just one question were do you live i cant figuar it out
93 4X4 auto
cummins king
Postby OLDEARL93 » Sun Jan 27, 2008 7:48 pm
HEY KING TRIED TO VISIT THE SITE BUT NO LUCK , I GUESS YOU ARE TALKING FROM EXPERIENCE HOW DOES IT HELP , MY GUESS IS THAT NOW I REACH 2100 TO 2300 AND THE POWER BAND GOES AWAY , TOP OUT THAT IS , BUT MY GEARS ARE ALSO TOPING OUT SO AS I ANALISEIT ,DOES IT HELP ON THE BOTTOM END , CONFUSED I AM
OLDEARL93
Postby cummins king » Sun Jan 27, 2008 8:43 pm
copy and paste in to the address bar, great mod wont be disipointed
93 4X4 auto
cummins king
Postby cummins king » Sun Jan 27, 2008 8:44 pm
its more responsive all the way up, longer fueling
93 4X4 auto
cummins king
Postby OLDEARL93 » Tue Feb 05, 2008 9:09 pm
WHERE CAN i ORDER ONE
OLDEARL93
Postby ford69557ci » Wed Feb 06, 2008 12:13 am
piers sells them or any bosch pump shop should be able to order one
ford69557ci
Postby JD730 » Wed Feb 06, 2008 6:52 am
cummins king wrote:http://dens-site.net/Dodge_CTD/Gover...ing/index.html
Where did you copy that from?????? Its missing half the address. I'm guessing, but it looks like you grabbed it out of the DTR sticky. Open them first then copy the address from the browser. For what ever reason that system likes to chop links down to a certain length on the text, but the actual link embedded is correct and does work. Thats why you see the "..." in the middle of the url address.
http://dens-site.net/Dodge_CTD/Governor_Spring/index.html
Mike
The "Rattle Box"
JD730
Postby cummins king » Wed Feb 06, 2008 7:43 am
Thanks JD
you can also get it from you local bosch shop or any ic pump shop
93 4X4 auto
cummins king
Postby GO OVRIT » Wed Feb 06, 2008 4:40 pm
I put mine in sunday afternoon. I can't believe it made that much of a difference. The truck feels a lot better. I went ahead and turned the fuel pin since I had it out. Thought about removing the afc, but if I put 370s or 435s in I'm worried how it'll tow.
Oh, and I got my spring from Piers diesel.
GO OVRIT
