TURBO CHANGE
TURBO CHANGE
Postby OLDEARL93 » Sat Jan 26, 2008 9:00 pm
CHANGED MY TURBO TODAY , FROM A ORIGINAL ON TRUCK TO A H35 12 WATE GATED ,ALL WAS WELL ,CRANKED YTHE ENGINE FOR 30 SECOND PLUS PLUGGED THE HOT BACK TO THE PUMP STARTED THE ENGINE LET IT RUN FOR A WHILE ,ABOUT 2 MINUTES DROVE IT REAL EASY FOR SOME BOCKS THEN AT LOAD IT SMOKED WHITE WHAT IS UP WITH THAT , DID I GET SOLD A BAD TURBO ,ANY ONE HAVE THIS PROBLEM THANKS
93 4X4 EXTRA CAB 5 SP. GERT.EGT,BOOST ,RPM GAUGE,TIMMING AD,PUMP TWEEKED,NEW HX35,REST STOCK
OLDEARL93
Postby cummins king » Sat Jan 26, 2008 10:30 pm
check if theres any oil in you exhaust or intake, how cool is it when u started it , one of our 6.5 has a white smoke and it leaks oil a bit but when it heats up it goes away
93 4X4 auto
cummins king
