rotor heads
rotor heads
Postby fasttalker83 » Sun Jan 27, 2008 9:57 pm
Probably another stupid question but can you stick a 14mm head on an old pump that had a 12mm rotory on it have I have a 90 D350 with a 12mm rotor and would like to see if I could pick up a 14mm to give it more hp if this would help Thanks
fasttalker83
Postby ford69557ci » Sun Jan 27, 2008 10:07 pm
you can but with the 14mm head you will also need a larger set of sticks, a very good fuel supply system with larger lines larger pump larger filter housing, and alot more airflow to use all of that extra fuel.
ford69557ci
Postby cummins king » Mon Jan 28, 2008 6:33 am
probaly twins, just reaserch in previous postsall the modes that have to be done for this set up
93 4X4 auto
cummins king
