KTA: Question(s)
KTA: Question(s)
Postby studlybilly » Tue Jan 29, 2008 12:33 pm
I'm considering a 4bt build and have a few questions regarding the 14mm head upgrade. My setup would consist of the 14mm head and 45psi elec. fuel pump. Would this setup allow me to make 500hp?
98 Durango "High Class Hooptie" - rockwells, 53's, 4 wheel steer.
studlybilly
Postby cummins king » Tue Jan 29, 2008 5:20 pm
i dont know thats alot of power for a 4 cly, theres not many 6cly over 500hp, you would need a big set of twin turbos, large injectors, the stuff about the pump is unproven, your going to need a seal that noby can find and we dont know about the reliablilty yet, your far better off with a p pump, i know a guy not personal but he has a lder bronco with a four cly cummins p pumped and it only has 400hp and its really done up
so good luck
93 4X4 auto
cummins king
Postby KTA » Wed Jan 30, 2008 6:18 am
The 14mm heads I have are for a 6cyl, I don't know of any for a 4cyl. I would suspect 400hp on a 4cyl would be more reasonable with a 14mm on a 4bt.
Postby studlybilly » Wed Jan 30, 2008 9:35 am
KTA wrote:The 14mm heads I have are for a 6cyl, I don't know of any for a 4cyl. I would suspect 400hp on a 4cyl would be more reasonable with a 14mm on a 4bt.
Wouldn't the 4bt VE pump be the same design given the 4bt is a direct descendant of the 6bt? Is there any way to run a bigger head or anything? Sourcing a P-pump for this motor is tough and pricey, the motor was free in the first place though.
studlybilly
Postby studlybilly » Wed Jan 30, 2008 9:41 am
cummins king wrote:i dont know thats alot of power for a 4 cly, theres not many 6cly over 500hp, you would need a big set of twin turbos, large injectors, the stuff about the pump is unproven, your going to need a seal that noby can find and we dont know about the reliablilty yet, your far better off with a p pump, i know a guy not personal but he has a lder bronco with a four cly cummins p pumped and it only has 400hp and its really done up
so good luck
Engine would be balanced, studded and the turbo configuration would be a twin. The H1C would be feeding a TV8101 (108mm compressor wheel lol). So basically I do want a P-pump so I can crank the ever living snot out of this engine.
studlybilly
Postby Begle1 » Wed Jan 30, 2008 10:25 am
There were a few European websites floating around that had 14 mm heads for 4-cylinder VW applications. Right? Don't I recall something like that?
Postby studlybilly » Wed Jan 30, 2008 11:54 am
Well let me ask this then, from what I have vaguely been told the VE pump die's from fuel starvation since it can't cool itself? Wouldn't a high flow pump to feed the injection pump eliminate this problem? Or maybe route the fuel lines through a fluid cooler and pack dry ice around it?
studlybilly
Postby burnt_servo » Wed Jan 30, 2008 12:10 pm
what do you intend on doing with the 4bt , and why can't you use a 6 bt ?
your looking at investing a pile of money here to reinvent the wheel and create a unreliable lump of iron .
do you have the 10 to 12 grand to invest into this motor to do things properly ?
4bt parts are pricey compared to 6bt .
burnt_servo
Postby burnt_servo » Wed Jan 30, 2008 12:14 pm
Begle1 wrote:There were a few European websites floating around that had 14 mm heads for 4-cylinder VW applications. Right? Don't I recall something like that?
14mm ..... really ....
off to go find a set for my vw :D
burnt_servo
Postby studlybilly » Wed Jan 30, 2008 12:45 pm
burnt_servo wrote:what do you intend on doing with the 4bt , and why can't you use a 6 bt ?
weight, and this 4bt would be going in my durang-ho for offroad application(s).
I don't see where everyone gets the 10k benchmark price? Maybe I just have connections but my build thus far is as follows:
ARP Stud kit - $300
Balance rotating assembly and o-ring head - $350
14mm pump head - $257
Injector nozzles custom cut - $300 (guessing here, haven't got a quotte)
I'd really like to look into fire ringing
Girdle - $180
TV8101 - already have
What am I missing that is so expensive and significant? Either way I'm not at a loss, I already have a 503 BBC on the cutting board at a machine shop. Which I intended on running the TV8101 on, I just have a couple 4bt's and have always been intrigued with diesels.
Another thing is I don't really grasp the application of power that the diesel gives. Along with the fact that torque is the main goal. So I tend to base my figures on HP numbers comparable to gassers since that's what I know as far as seat of pants feel. I don't how 400hp/800lbft+ @ 2500 RPM's compare's to a gasser with 800hp @ 5000 rpms.
studlybilly
Postby burnt_servo » Wed Jan 30, 2008 1:00 pm
so basicly you need a reliable engine first , since it's going to be used offroad ......
get the engine installed and running first , STOCK ..... then drive it and work the bugs out ..... THEN modify the engine .
even at 200 hp levels , your going to have difficulty keeping the dakota's running gear in one piece , unless your carefull .
burnt_servo
Postby studlybilly » Wed Jan 30, 2008 1:04 pm
burnt_servo wrote:even at 200 hp levels , your going to have difficulty keeping the dakota's running gear in one piece , unless your carefull .
I promise you this running gear isn't going anywhere, my truck/build consists of
Built TH475 transmission
Ford NP205 floater t/case, 1410 u-joints
Rockwell 2.5ton toploaders w/ 2" chromoly shafts
currently 53" michelins on stazwork rims, but soon to be 57"+ tractors
:D
**EDIT** and no, I'm not careful with my hooptie, I beat it like it owes me money.
studlybilly
Postby RumbleFish » Wed Jan 30, 2008 1:26 pm
pics?
Postby studlybilly » Wed Jan 30, 2008 1:32 pm
studlybilly
Postby oldestof11 » Wed Jan 30, 2008 1:57 pm
Yep, bubba, that some huntin' rig rite thar! :lol:
J/K, VERY NICE!
Now, what is a TH475? Is it bigger than the TH400?
