surging
surging
Postby A_port93 » Wed Jan 30, 2008 12:00 am
under wide open throttle my motor will sure and jerk back and forth.the boost will die down with it.does this sound like a lack of fuel pressure at higher rpms?if so is it time for a 2nd gen lift pump or an electric pump?
93 w250 getrag 220k 60/12wg over an ht3b/26 and ddp sticks, south bend ofe
A_port93
Postby cummins king » Wed Jan 30, 2008 6:51 am
i dont know but usaly the ve pump can suck its own fuel if the pump done to a certian degree, check the fuel filter first
93 4X4 auto
cummins king
Postby ford69557ci » Wed Jan 30, 2008 8:26 am
when my lift pump went it did the same thing thats why i now have large lines and an a1000 pump
ford69557ci
Postby A_port93 » Wed Jan 30, 2008 11:25 pm
do any of you guys have suggestions for what style of lift pump to go with?i hear that a piston lift pump with the correct pressure setup will perform pretty good but im sure that an electric will beat the sthi out of a piston lift pump for some more bucks...also whats involved with installing a fuel pressure gauge on our trucks?
A_port93
Postby A_port93 » Wed Jan 30, 2008 11:51 pm
A_port93
Postby ford69557ci » Thu Jan 31, 2008 1:25 am
if you dont plan on goin to wild with the power then a p pump engine piston pump with a bypass regulator would be the ideal setup for the money but if you plan on makin big power than somethin like an aeromotive a 1000 a bypass regulator and some large line are the way to go.
ford69557ci
Postby A_port93 » Fri Feb 01, 2008 10:11 am
hey guys i wanted to know if anyone had the part number for the piston lift pump that people use for the ves. i think that lift pump is available in two different pressure feed settings and i think the ve needs the lower pressure but maybe not.i want to get this done as soon as possible tho
A_port93
Postby ford69557ci » Fri Feb 01, 2008 5:32 pm
ford69557ci
Postby randyswelding » Sun Aug 17, 2008 7:52 pm
ok so what if i did that swap, but it now sounds like it is surgin also.you can tell by the sound of the exhaust when drivin any ideas it is a new low psi pistion lift pump
'92 D350 cab and chassy,pump turned up with 1/8 timin,coaltriann 6x16 sticks,htt manifold,asa intake cooler tubez,south bend 13" clutch rebuilt G360,ps cooler,industrial super 62 phat shaft turbo,weldin bed.
12 Chevy 3500ltz lifted, deleted, and bed with sae 300 ss hood for new rig
randyswelding
Postby fergavs » Mon Aug 18, 2008 7:12 am
When I had my stock turbo and lots of fuel I could make my turbo surge in the low RPM. Its like the motor is chuging. The reason for this is you are spooling the heck outta the turbo but the motor doesnt need all that air yet so the turbo "stalls".Basically the air coming out of the compressor hits a road block of compressed air that the motor hasnt used and has no where to go but backwards into the turbo. This is real hard on turbos. If your making lots of boost at low rpm and it feels like the motor is jerky/chugging/surging this may be your problem. Not a bad problem thou, means its time for a turbo upgrade. LOL.
fergavs
Postby randyswelding » Mon Aug 18, 2008 4:32 pm
that could be but how about 0-15psi of boost or i could be wrong it could be higher i havent looked at the gauge when its doing it,too much fuel for the stock turbo idea i like a lot :D new s300 will be on order after schields event
randyswelding
Postby randyswelding » Tue Aug 26, 2008 4:27 pm
i was wrong i was loosing my pinion bearing and thats what would hold the truck back and groan a little
randyswelding
