Drawbacks to extended plug-in..
Postby IRoss » Thu Jan 31, 2008 3:33 pm
I mean I'm wondering if having our engines plugged in for several days in moderate winter temps (around 0) has any unpleasant long term drawbacks ( aside from sucking power, burning out the element, and possibly rotting out the block heater seal)...i don't really have a good excuse for why this happens, other than the fact that I leave my truck for days on end to go have too much fun.... 8)
91.5IC 4x4 5spd extra springs
valet, 190s, ,18cm, 4"ëxh.
H4 conversion w/relays
rwal mia w/prop. valve
IRoss
Re: Drawbacks to extended plug-in..
Postby flashgordon » Thu Jan 31, 2008 5:09 pm
IRoss wrote:I mean I'm wondering if having our engines plugged in for several days in moderate winter temps (around 0) has any unpleasant long term drawbacks ( aside from sucking power, burning out the element, and possibly rotting out the block heater seal)...i don't really have a good excuse for why this happens, other than the fact that I leave my truck for days on end to go have too much fun.... 8)
I would say not a good idea!!!!!! although i have done it a time or two my self :oops:
Flash
flashgordon
Postby Ace » Thu Jan 31, 2008 5:10 pm
Why not use a timer, or only plug it in the night before you plan on using it next?
Ace
Postby PToombs » Thu Jan 31, 2008 5:17 pm
I'm sure it will shorten the life of the heater, but it's made for that! As long as the heater is submerged, and the A/F is a 50/50 mix, it should be ok.
A timer is a good idea, I've used them a lot. On at 5 am, off at 7.
Of course, if you don't know when you're going to jump in the truck and go, leave it plugged in! :lol:
Postby Begle1 » Thu Jan 31, 2008 8:10 pm
Would the heater really know the difference from being plugged in 6 hours or 48 hours? I wouldn't think so.
Postby JD730 » Fri Feb 01, 2008 6:50 am
PToombs wrote:A timer is a good idea, I've used them a lot. On at 5 am, off at 7.
If you have to leave it plugged in all the time you could get one of the bigger timers that have on/off clips that you can add on to the wheel and set it up so its one for 2 hours and off 2 or 3, then on again, so and so forth..... That would at least cut some energy usage and still keep the block warm.
Just a thought.
Mike
The "Rattle Box"
JD730
Postby cummins king » Fri Feb 01, 2008 6:54 am
should be fine just a bit more ware in tare
93 4X4 auto
cummins king
